Ford flat head ice in radiator
Old Jan 1, 2016 | 11:45 AM
Rick Webb's Avatar
Default Ford flat head ice in radiator
I have a 1950 ford with a flat head v8 went out to chekhov it this morning and have ice in the Radiator so I assume I've got a frozen or near frozen block. Any thing I can do?
Old Jan 1, 2016 | 12:53 PM
Have a small heater available? Wouldn't take much, could tarp the engine bay with some heat from below before it goes solid..
Old Jan 1, 2016 | 01:01 PM
Rick Webb's Avatar
Thanks I was going to do a heat lamp, maybe do a heater Instead
Old Jan 1, 2016 | 01:04 PM
Could also pick up a oil pan heating pad to help with the block, but the radiator still cold stick depending on outside temps and coolant/anti ratios.. Or 2, one on each.. Cooling system heaters are available as well, but if this is a temp outside situation or a surprise due to low anti freeze content, then just some concentrated heat, extra anti freeze added, and/ or removed from the frosty enviro..
Old Jan 1, 2016 | 05:40 PM
This brings back some distant memories of why they were called "freeze out plugs".
They probably served a dual purpose one was to allow the plugs to blow out in the event of a freeze and the other was to allow castings debris to be removed after the foundry was done making the blocks. Not sure how well they worked with a serious freeze.
Old Jan 1, 2016 | 09:31 PM
We had a very unusual hard freeze in the SF Bay Area many years ago that did a fair amount of damage to water pipes, un seasoned protected engines too. I had my boat 455 Olds, in a storage facility and thought, no worries. Later on in the week I went and checked it to find the freeze plugs in the bilge.. Many weren't that lucky...
Old Jan 4, 2016 | 01:49 PM
Shay_Fox's Avatar
Thanks for the info..
CANAD-EXPY
Jun 12, 2014 05:44 AM
dragbike425
Jun 5, 2009 10:43 AM
leland
Mar 27, 2007 04:47 PM
techmanbd
Apr 29, 2006 06:15 PM
hicracer
Jan 31, 2005 10:16 PM
