Help! Sytem Too Lean codes 2002 Explorer SES light and truck dies at idle
Old Feb 21, 2008 | 01:05 PM
Hansen317's Avatar
Default Help! Sytem Too Lean codes 2002 Explorer SES light and truck dies at idle
Hello everyone,
New here and not much of a technical person but can do normal type work on my trucks and boat. Searched but not sure which advice to start with. I have a 2002 Explorer V8. The Service Engine Soon Light is on. The engine runs ok cold but sputters and dies, during idle, once it is luke warm. The codes are: P01171 System too lean (bank 1), P0174 System too lean (bank 2), P1131 Manufacturer Contrl. Fuel Air Metering, P1151 Manufacturer Contrl. Fuel Air Metering.
Any advice on what could be wrong or where to start to fix this problem without taking it to the dealership ($$$$)?
Thanks in advance for any input.
hansen317
Old Feb 22, 2008 | 02:18 PM
Use Common Sense's Avatar
Default RE: Help! Sytem Too Lean codes 2002 Explorer SES light and truck dies at idle
Sounds like the typical intake gasket issue. Could be uppers or lowers.
Old Jul 19, 2008 | 06:23 PM
jexplorer's Avatar
i had a 1999 explorer until i traded it in yesterday.i had the same problem with mine after chasing the issue. try easiest to hardest:
1. mass air flow sensor- unplug and compressed air clean it even possibly replace, cheap on ebay. don't go to dealer!!!!
2. replace idle air control sensor- cheap on ebay
3. oxgen sensors
4. vacuum leak
5.your prior answer of the intake manifolds upper/lower
that is all i had to go through before it was found to be the vacuum leak. chased the problem over the periodof overayear. be sure to disconnect the negative battery cable every time to reset the computer and check engine lights. reconnect and drive it.
Maint007
Dec 7, 2014 04:57 PM
04f150dude
Oct 21, 2010 06:15 PM
nicktodisco
Aug 25, 2010 06:43 PM
ctrujillo2000
Jan 8, 2009 09:45 AM
jeffandteneka
Feb 16, 2007 09:58 AM
