Idle and Horsepower Problem
Old Jun 21, 2006 | 07:51 PM
myersem2's Avatar
Default Idle and Horsepower Problem
I own a 98' Explorer V8. I have had a problem with what I though was "missing". So i changed out all the spark plugs and this worked good for a while. Now however, it seems to have come back with a low idle and also it sometimes dies now. I also seem to have lost some horsepower, visible by the pick up, which I am sure has to do with this problem.
I am not sure what the problem is and rather than replacing parts at random like the fuel pump, Idle Air Control Valve, spark plug cables ect. I would like to know what is causing this. Is there any way to test these to help eliminate possible causes? Any help would be appreciated.
Thanks
Old Jul 1, 2006 | 06:00 PM
mikiemiky's Avatar
Default RE: Idle and Horsepower Problem
Have you figured out your problem yet. I have 98 Ranger doing sort of the same thing.
Old Jul 2, 2006 | 12:35 AM
Mulletman's Avatar
Is there a Check Engine light on? If so, get a scan and post the codes here. If not, then it may be fuel system related (Fuel Filter?)
ikjones
Nov 3, 2023 02:40 PM
santaclaus57
Jun 13, 2007 06:56 PM
matt2007
Jan 31, 2007 11:56 AM
shel67
Sep 29, 2006 08:19 PM
djb1607
Aug 24, 2005 01:28 PM
