Ignition Switch wiring diagram
Old Jan 17, 2018 | 05:36 PM
73FordF250's Avatar
Default Ignition Switch wiring diagram
So I changed this part, thinking I wired it correctly but the truck won’t start. What else could it be?
Old Jan 18, 2018 | 07:58 AM
Even a crystal ball would have trouble with the info you provided, need more !
What was the original problem and I am trying to remember where the ign switch was located, at the lower left of the dash?
Has the vehicle been used some or just left setting around?
What checks have you done?
What engine, and what is in the distributor, contact points, dist module mounted on the sheet metal someplace , the more info you can provide the better the chances of being able to offer a/some hopefully useful suggestions to get it running.
Also do you have any carb/choke cleaner to shoot into the air intake , one two second shot, to possibly eliminate a fuel supply problem.
marksatterfield
Apr 9, 2013 01:48 PM
jtmalott
Feb 26, 2013 11:21 AM
Mr. Din
Aug 22, 2011 04:53 PM
gregorys81
Jan 15, 2007 06:49 PM
caliba
May 3, 2005 02:54 PM
