Im certain my mechanic junkyard swapped me.
Old Dec 25, 2021 | 11:38 PM
LowBlackFast's Avatar
Default Im certain my mechanic junkyard swapped me.
***2012 Ford Flex 3.5 duratec
I apologize in advance if I'm in the wrong spot, I'm on a wild goose chase all over the web.
About 5 weeks ago the wife left home, cold start, made it about 3 miles. She called and said the vehicle was over heating, steaming, and that she had stopped and shut the vehicle off. When I arrived from home, coolant was boiling out of the weep hole of the water pump into the valley. I am aware of the water pump issues of this engine, and against my better judgement I had it towed to a respected mechanic in my area.
After 5 weeks and nearly $3k, we drove it home Monday the 20th. Less than a week, and 50 miles later it spiked in temp, made a "poof" noise like a hose or gasket, then began to stumble. Water everywhere.
​​​​​​Here's where I start to get pissed. It looks to me that the valve cover from our original engine was placed on a swapped motor. The service receipt suggests that the primary and secondary chains, tensioners, guides, water pump, and fluids were replaced. But the engine is covered in sand, dirt, grime. The front valve cover shows no sign of being removed. Alternatively the rear cover, that conveniently bears the serial number of the engine, does show signs of recent wrenching. In fact, the fasteners that seem to show signs of recent work are those only required to remove the engine.
I need help. Can duratec owners only really be sure that the valve cover belongs to the original vehicle? Or are there other identifiers that can be compared to determine if my accusations are correct?
Old Dec 30, 2021 | 12:25 PM
uhoh's Avatar
Rotten way to end out the year
Old Dec 30, 2021 | 01:34 PM
scott.butler4's Avatar
May I recommend you specify what model, year, engine your vehicle has.
jdux
Dec 6, 2017 05:15 PM
Phillips73
Apr 15, 2015 01:30 PM
topgeye
Sep 1, 2012 12:04 PM
wannabegreasemonkey
May 16, 2009 08:37 PM
Samson
Mar 11, 2009 06:35 PM
