info on my ford motor
Old Nov 2, 2008 | 06:42 AM
  #11
Use Common Sense's Avatar
Default RE: info on my ford motor
The HiPo engine was engineered to increase performance and high-RPM reliability over standard 289. It had solid lifters with hotter cam timing; 10.5:1 compression; a dual point, centrifugal advance distributor; smaller combustion chamber heads with cast spring cups and screw-in studs; low restriction exhaust manifolds; and a bigger 595 CFM carburetor vs. the standard 289 which had a 480 CFM carburator. The water pump, fuel pump, and alternator/generator pulley were altered; fewer vanes, extra spring, and larger diameter respectively; to help handle the higher RPMs. Even the HiPo’s fan was unique. Bottom end improvements included thicker main bearing caps and balancer, larger diameter rod bolts, and a hardness tested and counterweighted crankshaft, all for high-rpm reliability.
Compare the bottem end components of a 289 and a 289 HiPo, then compare those to yours.
mkaresh
Apr 4, 2017 11:15 AM
ShtKickinCowgirl
Apr 16, 2014 10:06 PM
conanalois
Aug 31, 2013 06:16 AM
toaaronuu
Apr 30, 2008 05:52 PM
vdwightj
Dec 15, 2004 09:38 AM
