Knock knock
Old Jan 11, 2018 | 08:22 PM
Flounder35's Avatar
Default Knock knock
I have recently converted an f250 engine to fit my f150 truck. 2005 model. The knock sensors are different. The f150 won’t fit the motor and the f250 sensor won’t fit the wiring what do I do?
Old Jan 13, 2018 | 11:38 AM
greasemark's Avatar
actually, While they may be different sizes, I believe they are the same thing. From a "make it work" perspective, as long as they're bolted to the block and wired in, they should work.
if you can mount it, then just get a pigtail to fit whatever you need and splice it.
Old Jan 16, 2018 | 08:28 PM
Flounder35's Avatar
Ok the sensor has two wires. A black and a yellow wire. As far as I can tell the truck side has only one wire leading to the connector. Are both black and yellow wires hot or is one of them a ground? Thanks
mustang fox
Dec 14, 2015 01:36 PM
ROFFL
Oct 5, 2007 12:26 PM
e_de_anda
Feb 5, 2006 05:01 AM
blewis
Nov 13, 2005 02:44 PM
FRANKENSTEIN69
Jul 14, 2005 03:06 PM
