Magnet in transmission
Old Feb 17, 2014 | 11:23 AM
bobepan's Avatar
Default Magnet in transmission
I just replaced the transmission fluid in my 1977 e150. There was no magnet in the pan. I put a ceramic magnet in the pan before replacing it. It is an iron pan, not aluminum. Is there a possibility that that the ceramic magnet could create problems for the transmission? If so I will take it back apart and remove the magnet before driving it. Thank you
Old Feb 17, 2014 | 02:31 PM
If I recall correctly there was a dimple in the pan that kinda kept the circular magnet in place. As long as the magnet is the same size and has a hole in it to keep it there, should be OK.
Old Feb 17, 2014 | 04:55 PM
bobepan's Avatar
Thank you
bobepan
Feb 17, 2014 12:24 AM
