Messed up
Old May 18, 2017 | 06:24 PM
Bfalba3's Avatar
Default Messed up
Ok so I accidentally put transmission fluid in the def tank on a f-550 dump truck at work today. I only put 2 quarts in though. What's going to happen?
Old May 18, 2017 | 07:53 PM
Bfalba3's Avatar
No ones knows what will happen ?
Old May 18, 2017 | 10:11 PM
Oil and water based Urea are not going to mix in an intended and fairly sterile system. Oil into the system is never good for DEF/SCR Catalyst systems even in trace amounts. Putting DEF into the fuel would have been very expensive, but the trans fluid,, the tank should be cleaned, and all of the contamination removed. Running the truck with the contamination can/would possibly damage an expensive system. Even a system run with only water added to the DEF will result in running issues.
86broncokid
Jul 14, 2012 04:32 AM
angelique659
Feb 24, 2010 03:02 AM
Vicky
Jul 8, 2008 06:24 PM
Patch1985
Jul 11, 2006 05:03 PM
gwald
Mar 26, 2006 01:09 AM
