Misfire in multiple cylinders..
Old Mar 25, 2018 | 10:22 AM
Vincent Ramos's Avatar
Default Misfire in multiple cylinders..
2006 Ford Escape. Code showing misfires in 2, 3 and 4. Pulled the plugs and 5 and 6 are showing use but 4 still looks new???
Old Mar 25, 2018 | 01:20 PM
If you switched coils with say 4 & 6 , does 4 still show a misfire?
Old Mar 27, 2018 | 07:55 PM
yes.. switched coils and misfire still in original cylinder. was told possibly the PCM????
Old Mar 28, 2018 | 02:39 PM
The PCM provides the ground for the coil to charge and when it opens the circuit(removes the momentary ground ) which creates the spark from the coil.There is a way to confirm if the PCM is grounding the coil when it is supposed to do that. If you know the coil is good and there is constant power to the coil(12 volts) just put a spark plug into the coil terminal and lay the plug against any part of the metal of the engine. You should see the spark at the plug with the engine running. If you know the plug and coil are good and you get no spark that leaves either the wiring from the PCM to the coil or the PCM as faulty. It doesn't make sense to replace a PCM unless you eliminate all the other possible causes AND now the replacement PCM has to be programmed to your particular vehicle or you could come up with a new no start problem. After that if you decide to put the old PCM back in , it still will no longer start . You cannot just switch PCMs without programming the replacement PCM to your vehicle. the security system makes sure of that.
DanNeedsHelp
Mar 31, 2015 03:38 AM
DanNeedsHelp
Mar 28, 2015 08:07 PM
umoms
Feb 2, 2013 10:30 AM
richardapu
Nov 4, 2009 06:14 PM
Heavyfoot
Jun 8, 2007 03:25 AM
