missing coolant!
Old Dec 15, 2006 | 12:49 AM
69wert's Avatar
Default missing coolant!
hi, every one i have an windstar 98 and three weeks ago i put a new heads all the gaskets are new and now on every trip even if it is small i have to put coolant and somtime she also she is smokes by the exhaust but is no all the times.the oil motor is clean,in the cover cap i see milky subtances and also and in the pcv too. she is running nice ans rpm is 800 and besides all this all else is all good.if anyone have any idea please let me know thank[sm=dontgetit.gif]
Old Dec 15, 2006 | 03:09 AM
Default RE: missing coolant!
What was the original reason for pulling the heads? Head gasket failure I'd assume..
So,,,,
'Both' heads were replaced, new head gaskets, AND new headbolts? Were the heads reman. replacements, used, or the originals as rebuilds? Are you certain the head gasket/s weren't damaged during the build/install.. Had it ever seriously overheated?
Old Dec 16, 2006 | 12:25 AM
69wert's Avatar
hayapower but the oil is perfec overheated no way
Old Dec 16, 2006 | 12:33 AM
69wert's Avatar
i move the upper intake and no see nothing bad no milky oil
Old Dec 17, 2006 | 06:03 PM
wheelsup68's Avatar
Are the heads new?
Just the gaskets?
Sounds like a crack in the cylinder head.
Old Dec 19, 2006 | 11:19 PM
69wert's Avatar
I fix the last problem just with a radiartor flush https://www.fordforum.com/micons/m16.gif
thanks everyone
now i need if someone can help me found a pair of headers to 3.8 v6 fordhttps://www.fordforum.com/micons/m5.gif
Old Dec 19, 2006 | 11:21 PM
69wert's Avatar
javascript:void(AddText('[:\-]'))
Old Dec 21, 2006 | 11:49 AM
seholstein's Avatar
It sounds like a crack in the head, or the head gasket got damaged during the install process.
Old Jan 24, 2007 | 04:21 PM
tomb1269's Avatar
Could also be coolant leaking through the the lower timing cover bolt. The 3.8 has atiming cover bolt that extends into the water jacket that the thread seal can deteriorate and cause coolant to leak on to the crank thrust bearing. To check start the engine cold run 10-15 seconds (yes second) to pressureize coolant system, shut down and check the edge of the catalatic converter for coolant. You will also tend to smell the sweet smell of cooked coolant but never find a wet spot and the water pump will not be the source. I had a 95 W-star bought used, found leak, took to dealer for leak, leak was in timing cover and had to replace timing chain. 5 weeks later started getting bottom end noise, end up having to have new motor.
TomB1269
2002 Ranger
2006 Freestar
2005 Jayco Popup
69wert
Dec 15, 2006 12:49 AM
speedyberetta86
Apr 8, 2006 09:20 PM
muzfvfc
Feb 10, 2006 02:54 AM
Edwards
Nov 25, 2005 04:16 AM
Grant
Mar 10, 2005 12:18 AM
