need help! 2001 crown vic brakes locked up
Old Sep 23, 2013 | 10:44 AM
mustangstreet66's Avatar
Default need help! 2001 crown vic brakes locked up
hey guys i got a 2001 crown vic. my friend was driving it and he said the abs light popped on when he got home you could smell the brake smoke. i popped the hood and there was no brake fluid. i added brake fluid and the light was still on. how do i unlock the brakes and get the abs light off?
Old Sep 23, 2013 | 01:46 PM
I believe you/he has a more serious concern right now and that is to determine why all the brake fluid was lost. Could it be the pads were never checked and wore to the point where the caliper could no longer compensate and possibly jammed the remaining part of the pad against the rotor destroying the caliper and cooking the seals and allowing the fluid to go out? Let's hope not. Just speculation at this time because I have seen this more than once.
Old Jan 29, 2014 | 11:20 PM
William Robert Kuck's Avatar
My mom had a 2001 Lincoln Continental Towncar *Signature Series* w/ 500 miles on it when, the rear brake calipers which have carbon fiber pistons in them, and after 6 months the calipers were shot, and the stealership tried to tell me that they had to be replaced, and the pads as well as the rotors too, I pitched a fit because I've worked in the aviation industry (plus I've worked on cars since I was 10,and now I'm pushing 42), and if the carbon fiber had so much as a tiny bubble in the carbon fiber piston it will break given enough pressure, so I told them there's NO way we're paying for a set of pads, rotors and calipers that, plus we hadn't even gone through first set of pads on the front yet, so I told them I'll pay for labor and NOTHING ELSE and that's all we paid for, so I suggest you check your rear caliper pistons.
Draxxon
Apr 11, 2015 09:41 PM
mustangstreet66
Oct 5, 2013 11:10 PM
wantz_a_shelby66
Apr 28, 2010 07:29 AM
F350forSALE
Oct 28, 2007 09:06 PM
jeninejessica
Apr 6, 2006 02:08 AM
