need help 66 ford
Old Aug 23, 2009 | 12:17 PM
956's Avatar
956
Question need help 66 ford
ok so i have a 66 ranchero and it will start acting sluggish when i try to give it more juice , not a lot more just some, then after a little bit of that it will die and wont start back up like the battery is dead but the lights still come on and everything. then when i jump it it starts and then lasts for a bit but not long and i have to do it all over again. ive replaced the battery, alternator, solenoid switch, voltage regulator, and the starter has been checked. any sugestions?
Old Aug 23, 2009 | 03:16 PM
FordMan59's Avatar
Have you checked the battery cables to make sure they are clean and tight at the battery, ground and starter and checked the condition of the cables for cracks, broken insulation where dirt or corosion may have got in them restricting the flow of electricty. If the cables look good check them for burnt spots or weak spots that may indicate broken wires inside the cable.
BigRig Mechanic
Feb 26, 2009 06:12 PM
streetbob
Jun 17, 2008 05:01 PM
Adhd
Feb 3, 2008 09:55 PM
hoppy
Jan 15, 2006 01:47 AM
FE84
Feb 8, 2005 06:06 PM
