need torque specs: e350 Ford 2014 v10 6.8L gas with AC
Old Nov 8, 2025 | 12:09 PM
phcurt's Avatar
Default need torque specs: e350 Ford 2014 v10 6.8L gas with AC
Working on replacing some broken exhaust manifold studs,
Especially need exhaust Manifold torque specs (both stud and nut) for: e350 Ford 2014 v10 6.8L gas with AC,
Also like torque specs for wheel lugs. Thx.
Old Nov 8, 2025 | 12:23 PM
A little tip,,,,,,,,,,,when installing studs . never hurts to use some "Never Seize on the hardware for the next time you might need to remove them..
Old Nov 9, 2025 | 09:40 AM
phcurt's Avatar
I do plan to use anti-seize but sparingly, especially after reviewing this (some things many do not realize):
youtube channel: torque test channel,
video: (Jump in at 16:39 about effects of anti-seize) You're Using a Torque Wrench Wrong: MythBusting 10 Do's & Dont's
Still trying to find reliable answer on torque specs for exhaust manifold. Anybody?
Old Nov 9, 2025 | 11:35 AM
You must be careful not to allow any anti seize to get into the exhaust stream where it can render an oxygen sensor useless, and that sensor can be located AFTER the catalytic converter.
Kelly66
Oct 12, 2024 12:19 PM
kodiakE350
Aug 16, 2024 06:35 AM
Colts2193
Jun 28, 2018 10:21 PM
James3528
Aug 31, 2011 10:09 AM
chiefsta3
Aug 31, 2007 08:54 AM
