Not Starting
Old Nov 21, 2008 | 11:54 AM
drew3300's Avatar
Default Not Starting
I have a 2000 F-150 5.4L. It's having a lot of trouble starting, hot or cold. Once it does start it runs great. No erratic idle and driving is normal. Any ideas??
Old Nov 22, 2008 | 09:44 AM
Use Common Sense's Avatar
Default RE: Not Starting
May not be the problem, but a bad DPFE sensor can cause starting problem regardless of the engine temp.
Old Nov 28, 2008 | 12:48 PM
ford 4315's Avatar
I would go to Auto Zone and have the codes pulled for free. This will save you money.
Also you may want to look for vacuum leaks or more importantly a dirty MAF sensor.
If you are in the Orlando, Fl are look up Mobile Oval Automotive. They are Ford dealer Tech's and they charge about 1/2 of what the dealer will charge.
http://www.mobileoval.com
Nomer78
Jun 10, 2007 12:11 PM
1995FordRanger4WD
May 24, 2007 05:33 AM
cristafer5
Sep 11, 2006 07:45 PM
daz3nt
Jan 31, 2006 06:28 AM
MLGstang
Jul 12, 2005 07:56 PM
