Injector knock?
Old Nov 23, 2008 | 10:56 AM
hlfld165's Avatar
Default Injector knock?
I've got an02 7.3 Liter powerstroke, runs good lots of power. But it hasan awful knock at idle. Twice as loud as any other powerstroke i've heard.anybody got any ideas on what to check or were to start?
Old Nov 24, 2008 | 11:19 PM
Use Common Sense's Avatar
Default RE: Injector knock?
Try running some CETANE boost in the fuel. Believe it or not, but a lot of knock on a diesel is from pre-ignition.
Old Nov 28, 2008 | 12:54 PM
ford 4315's Avatar
This is normal for the 7.3. Trust me i have been a Ford dealer Tech for 20 years.
The problem is fuel pressure. Ford came out with a long lead injector for the number 8 cylinder but it didn't do much. The idea was if they held number 8 open longer it would get more fuel and reduce the noise. The #8 cylinder is the last to get fuel and by that time the pressure has dropped too much and causes what Ford calls " Fuel Cackle ".
The only way to fix it is to install an adjustable regulator and new pump.
Don't worry though it won't damage the engine. It's just annoying.
If you are in Orlando look up Mobile Oval Automotive. They're the best Ford diesel mechanics in Florida. http://www.mobileoval.com
ROFFL
Oct 5, 2007 12:26 PM
mach
May 1, 2006 03:47 PM
e_de_anda
Feb 5, 2006 05:01 AM
blewis
Nov 13, 2005 02:44 PM
FRANKENSTEIN69
Jul 14, 2005 03:06 PM
