P0712 code Ford F150
Old Feb 19, 2006 | 08:46 PM
dlear's Avatar
Default P0712 code Ford F150
I am getting a code P0712 on my 2002 Ford F150 5.4 automatic 4x4........ Dealer said transmission temperature sensor was
bad, installed new sensor and cleared codes, pulled trailer and OD light started flashing and code is back.Also constantly shifth in and out of OD when driving a steady speed between 30 mph and 50 and is worse when cold.Any suggestionswould be greatly appreciated. Also voltage readings when engine is warn are 0 volts to 1.7 if you rev up the motor. Temp sensor displays 380 degrees all the time.
maineman
Aug 11, 2018 08:23 PM
Bobbie Jo Short Thomas
Dec 30, 2013 02:47 PM
cwildkats
Dec 27, 2012 09:59 AM
dlear
Nov 20, 2008 06:32 PM
dwpkjp23
Feb 26, 2008 08:50 PM
