power sliding window
Old Sep 23, 2006 | 12:06 AM
hunting okie's Avatar
Default power sliding window
My power sliding rear window just recently quit working. All my other accessories are working and I believe the electric windows share the same fuse? Any ideas on how i can fix?
Old Sep 23, 2006 | 11:52 PM
94 4x4 ranger's Avatar
Default RE: power sliding window
If you can gain access to the motor tap it while holding the switch.If it runs the motor is bad.[hr]If no change try the fuse and test the switch with a test light or meter.
Old Sep 26, 2006 | 08:12 PM
masterexploder's Avatar
assuming it is an f-150, the power slider motors fail all the time, if you have any warranty left take it to a dealership and they should fix it for free, other wise you can chane it your self, all you have to do is...
1. remove plastic trim at top of seatbelt on back seat by poppin gof top plastic piece and removing the two 10mm bolts.
2. then this is the hardest part, you have to remove the seat back, take a large pry bar, and stick it between the seat cussion, and the seat back, you will see a metal loop sticking out on both sides , you pry against this loop against the seat back, you have to do this on both sides, it may take you a couple of tries.
3. then pull the seat back out and remove the three pushpins on the passanger side and pull back the cover.
4. the motor should be clearly visible in the center. the new motor comes with new cables too, but oyu dont need to put them on just remove the new motot and replace the old motor.
5. to reassemble simply reverse order, just make sure the clips on back of seat click in.
the only tools you should need is a small flathead screwdriver, a deep 10mm socket , a large pry bar, an 8 mm socket, a T30 torks bit, and something to remove pushpins like a trim tool.
if you have any questions please ask.
tjengland
Oct 16, 2010 12:03 PM
Four_Eyes
Jul 17, 2010 05:20 PM
d4tonyd
Jan 14, 2009 05:17 PM
Brooklyn67
Sep 8, 2007 12:46 PM
windstar man
Jul 4, 2007 12:37 AM
