replacing upper control control arm bushings
Old Sep 22, 2006 | 03:26 PM
shel67's Avatar
Default replacing upper control control arm bushings
hi, my 1995 ford aerostar has a worn upper control arm bushing on the driver's side. I've been quoted up to and over $300 to fix problem. I came upon a tool that supposedly removes and replaces upper controle arm bushings for late model ford vehicles wthout having to remove the upper arm assembly. Is this correct, and if so can anyone give me advice to fix problem?
Old Sep 25, 2006 | 08:40 PM
shel67's Avatar
Default RE: replacing upper control control arm bushings
cant anybody help?????
Old Sep 25, 2006 | 09:13 PM
masterexploder's Avatar
i suggest you take it to wherever quoted you $300 it is pretty labor intensive to replace, and i don't know if you want to put that much effort into it or not.
Old Oct 13, 2010 | 05:32 PM
sticks1158's Avatar
Default Upper Control Arm bushing replacement
MasterExploder
Thanks for your post! I feel a lot better, as I just had the driver's side upper control arm bushing replaced on my '96 Aerostar, and thought $225 was a bit pricey. Judging by your post, I should feel fortunate! Thanks again.
fillbilly
Mar 26, 2015 09:11 AM
69BirdWatcher
Dec 4, 2010 11:26 PM
intruderdt
Aug 30, 2010 11:14 PM
cfdeadc2001
Mar 9, 2007 10:50 PM
shel67
Sep 22, 2006 03:26 PM
