Runs Bad After Tune-up.
Old Feb 18, 2022 | 06:54 AM
JoelH.'s Avatar
Default Runs Bad After Tune-up.
Ran perfectly!
Only because it had 100k and a slightly leaking heater tube on the intake manifold, I tore down the top of my 97 econoline Triton 5.4l.
I replaced the tube, replaced the plugs, injectors, and coil caps, gaskets, and rotted vacuume lines.
I carfully reassembled and properly reconnected all caps and injectors, replaced suspect vent/vacuume lines.
I checked for any vacuume leaks, all ports were accounted for and connected.
It now starts fine, idles reasonably well, but won't take throttle without popping and sputtering and not excelerating.
Help!
Thanks in advance.
Old Feb 18, 2022 | 09:16 AM
raski's Avatar
You don't need to double post your problem. Look at your other post for direction.
JoelH.
Feb 20, 2022 01:58 PM
That-emt-guy
Aug 19, 2020 04:56 PM
Dodg3m4n
Aug 14, 2020 06:51 PM
RedEric
Apr 25, 2015 12:27 PM
markcross
Dec 30, 2008 02:10 AM
