Taurus-Sable 3.5 Engine Swap
Old Jan 14, 2022 | 07:19 PM
Deleof's Avatar
Default Taurus-Sable 3.5 Engine Swap
My '08 Taurus engine has a bad head gasket leak. I tried Blue Devil gasket sealer but it didn't work. I watched someone on YouTube replace the head gasket on a Taurus but it isn't easy to do and I don't have some of the tools needed. Now I know why garages charge so much. But, I have found either an '08 or '09 Sable at a junkyard. It was in a wreck and I'm pretty sure that the engine is in good shape. A parts puller checked it out and it isn't locked up and no chocolate milk in the engine and no oil leaks.
My question is, will is be an easy engine swap? Will a 3.5 from the Sable go right into the Taurus motor mounts? Is there anything that will make this difficult? Will there be any computer issue's, wiring issues? Any issue that will make this a bad decision. I'm not a trained mechanic and I do most of my auto repairs myself, but I've never tackled anything like this before. I appreciate any and all replys. Thanks
Old Jan 15, 2022 | 09:50 AM
There are a few things to consider.
Right now you know what you have with your vehicle, good and bad.
There could be some differences between a 2008 and a 2009.
The more things you undo the more you increase potential for problems, that is just the way it is.
Since you are contemplating swapping engines, you must feel your vehicle is worth the time and work.
Just with that knowledge you might come out better replacing both head gaskets ,,,,,,,,,,,,,,,,,,unless there is more to this than we know.
lcrosson
Mar 25, 2018 06:02 PM
Danielle Harrison
Feb 27, 2012 09:17 PM
JOET
Sep 25, 2008 10:00 PM
blixx003
Apr 11, 2007 11:05 AM
Vedoc
Apr 6, 2006 04:21 PM
