timing belts and engine wear
Old May 16, 2019 | 10:02 PM
bradleyheathhays's Avatar
Default timing belts and engine wear
I bought a 2011 Crown Vic with 300k miles 12 mos ago and I'm wondering how to approach servicing the timing belt. I know very little of it's past maintenance records other than what I've done with it this past year. Basically I'm wondering if I should go ahead and attempt to replace it now, or wait til something starts to go wrong. I don't know how timing belts typically go bad...if they just break or start to stretch or what. If this is an interference engine I'm imagining a fairly bad event so I'd like to get educated and be pro active about it.
Second...Scotty Kilmer teaches that the worst wear an engine sees after changing the oil is before the oil gets pumped back into the filter and then into the engine components during the first engine restart. But he says if you disable the ignition spark somehow when cranking for the first time again, the lack of combustion in the cylinders helps with reducing this kind of wear quite a bit. I don't have an owner's manual and I'm not sure what fuse to pull to disable combustion ignition, or if removing a fuse would be the best way to do this. Any opinions on how this should be done?
Old May 17, 2019 | 07:27 AM
Pretty sure there is no timing belt so don't be concerned there.
Frequent oil changes and using the correct or good grade motor oil is EXTREMELY important to help keep timing chains and tensioners working properly.
If you rap the inertia switch located in the trunk, and trip it , allowing the engine to run out of fuel and stall, when getting ready to drain the oil , you can do the oil and filter change attempt to start the engine, it will not start until you reset the inertia sw. Quick and easy way to prevent it from starting.
Old May 17, 2019 | 10:44 AM
No belt..
Oil priming a newly built engine (first start) is a good practice, but a run in engine not really required.
Oil remains in the pump body, crank, oil galleries etc, and upon firing oil delivery is nearly instantaneous other than the oil filter being filled which depending on filter orientation you could add some clean fill for piece of mind.
The amount of time to filter fill and register on the panel isn’t enough to cause any damage to the engine.. Race, HP aircraft and such, a different story...
ltramon45@gmail.com
Apr 15, 2014 11:51 AM
Richard7425
Sep 30, 2012 02:09 PM
andipoll
Feb 16, 2009 11:21 PM
chemoman
Jan 21, 2008 09:55 AM
chemoman
Jan 17, 2008 12:02 PM
