Tire Pressure Sensor Fault
Old Oct 21, 2023 | 10:54 AM
uhoh's Avatar
Default Tire Pressure Sensor Fault
2011 Fusion, 3.0 liter, V-6, stock 17 inch wheels. Wheels have not seen recent work; ~ a year+ since tires mounted. Photos.
Some 6 weeks ago warning message ("Tire Pressure Sensor Fault") came on. Tire pressure is/was good, but dinked with it anyway - didn't fix. Can't correct / eliminate message; it can be doused while engine running by reset button.
I googled "Ford Tire Pressure Sensor Fault" and followed the directions to reset (said to work on 2011 - 2021 Ford vehicles) - involving particular sequence (A) of brake pedal, start key, ..., and then display is supposed to show (B) "Train Left Front Tire" that indicates the 'training of the tires has begun' automatically (?). This latter (B) message does not show; fault message re-appears - several tries.
Anybody know of another way to fix this, what I'm doing wrong, or just insight? Help
2011 Fusion
17 inch stock wheels
Old Oct 21, 2023 | 12:20 PM
This usually requires a special tool to reset or check those sensors.
droidus
Oct 10, 2016 11:26 PM
pgc50
Feb 9, 2015 11:39 PM
hfb1957
Mar 18, 2013 03:00 AM
jlingram67
May 5, 2010 12:07 PM
bonjregdol
Nov 16, 2008 07:50 PM
