turn signal and wiper issues
Old Jul 16, 2025 | 01:24 PM
rond's Avatar
Default turn signal and wiper issues
I have a 2012 F150 Harley Edition, that the windshield wipers and the turn signals do not work, there is power and the fuses are good.
Any assistance would be appreciated.
Old Jul 16, 2025 | 02:32 PM
Simply remove the upper or perhaps the lower steering column cover, then remove the entire left stall, then separate the covers on the base of the stall, there should be a small circuit board, simply check for possible wiring problem, then you can spray electronic contract cleaner and see if it helps. I don't have any diagram for your 2012 though. If you can find one simply bench test the stall with ohmmeter you can also test the continuity and see if it's the problem of the stall, if it is just replace a new one, shouldn't be expensive.
Example shown below.
rkheath
Jun 29, 2025 11:19 AM
Cathy Bunnell
Mar 3, 2019 04:09 AM
stargate
Oct 28, 2013 06:26 AM
54Strife
Jul 13, 2006 12:55 PM
twy23
Nov 24, 2005 05:48 AM
