04 F150 XL 4.2 no fuel going to engine
Old Aug 29, 2015 | 07:33 AM
lilmp22's Avatar
Wink 04 F150 XL 4.2 no fuel going to engine
My F150 2007 4.2 is not getting fuel to the engine. I have changed my fuel pump, filters and the engine will not start. Also changed the purge sensor. Any advice out there??
Old Aug 29, 2015 | 08:54 AM
primem's Avatar
if the truck has an inertia switch make sure its not tripped.
do you hear the fuel pump running when the key is cycled to run? it should run for 2 seconds then shut off.
if not, check the fuel pump fuse. if the fuse is good check for power to the fuse and relay.
if the relay is clicking when the key is cycled to run, check for power and grd at the fuel pump connector at the tank.
Old Aug 29, 2015 | 09:58 AM
lilmp22's Avatar
Thank you! Will try these things and let you know how we make out!!
Old Aug 29, 2015 | 01:10 PM
lilmp22's Avatar
It seems that there is no power to the fuse box do you happen to know what is needed to fix that? I really appreciate your help
Old Aug 29, 2015 | 01:50 PM
Start at the battery + post and work your way to the place where you have no power.
You may have to look at the connections going to the CJB (central junction box) under the left side of the dash. Was the windshield ever replaced on this vehicle? They have been known to leak right from the factory and sometimes after windshield replacement. Look for corrosion on the back of the CJB.
Old Aug 29, 2015 | 01:55 PM
lilmp22's Avatar
Thank you so much for your help! It turned out to be the switch you mentioned earlier, I can't thank you enough!!!!
mikep43019
Aug 11, 2014 10:48 AM
graves
Mar 9, 2012 06:51 PM
daveranger
Sep 13, 2007 01:46 PM
johnny
Jul 27, 2007 04:07 PM
farris1307
Sep 9, 2005 04:59 PM
