1972 Ford LTD - Seek Correct Audience
Old May 19, 2022 | 06:18 PM
ruffy's Avatar
Default 1972 Ford LTD - Seek Correct Audience
What is a newcomer to do if he owns a new (old) Ford, enthusiastic to find a Ford Forum, only to discover that not even once in the entire forum is his car, an LTD, ever mentioned? (I didn't bother searching "Brougham") So what do I do, where can I visit here, to get answers regarding my newly acquired 1972 Ford LTD Brougham. For starters, I can't locate the horn, or how it's even supposed to work. I'll post my problems more elaborately and with pictures later
- if only someone would direct me to where on this forum I can post my question.
Thank you.
Old May 20, 2022 | 09:48 AM
I can help you maybe understand how the horn(s) are supposed to work.
Horns require a considerable amount of power to operate and that is provided by a horn relay that sends power directly to the horn(s) when energized.
When you depress the horn button/ring , it closes a ground circuit to operate the relay and when everything is right , the horn sounds. Pretty simple, huh?
Usually the horns , if nobody removed them, were located behind the grille under the hood latch.
Old May 20, 2022 | 10:38 AM
You can continue posting in to the 'General' threads, or, you can post to Other Makes, Models (Past Ford Models) section.
https://www.fordforum.com/forum/othe...or-company-37/
Old Jul 20, 2022 | 08:53 PM
ruffy's Avatar
Thanks hanky. Just put up my new horn issue. Hope you can help me.
It's posted here:
https://www.fordforum.com/forum/othe...ord-ltd-45609/
ruffy
Nov 8, 2021 10:16 PM
gtdorothy
Apr 4, 2017 04:59 AM
SK1PM8
Dec 14, 2015 02:15 AM
Lil_Turtle
Nov 25, 2013 10:15 AM
apu
Aug 25, 2013 11:28 PM
