1991 Ford F-150 problem
Old Sep 26, 2020 | 01:01 PM
Backwoods94's Avatar
Default 1991 Ford F-150 problem
Having issues with my 91 xlt lariat . It has the 5.0 . Running fine and just shut off one day . Turns over strong but won’t start. I checked the rail and it has pressure. Replaced the fuel relay module, filter, plugs , wires , distributor rotor and cap. Fuel pump seems to come on when they key is turned on. Looking for ideas or suggestions on what I could do next. Still turning over after all that but not starting. Thanks.
Old Sep 27, 2020 | 06:35 AM
raski's Avatar
Having pressure means little. How much do you have? Specs call for 30-45 psi.
You need spark at the right time, fuel, compression and air to run an engine.
Old Sep 27, 2020 | 07:47 AM
Tested pressure and it was okay. Found the issue, bad ignition module .
Old Sep 28, 2020 | 05:54 AM
Thanks for the update.
wheref15sdare@gmail.com
Jul 1, 2019 04:53 PM
soakem
Apr 12, 2014 04:18 PM
Kirkwa
Apr 26, 2013 08:53 AM
Spivey001
Feb 4, 2012 11:28 AM
bustedknuckles
Sep 15, 2007 01:33 PM
