1999 Escort ZX2 Keyless Entry
Old May 18, 2018 | 11:30 PM
Card820's Avatar
Default 1999 Escort ZX2 Keyless Entry
I need help in locating the keyless entry/anti-theft RAP module on a 1999 Ford Escort ZX2. My keyless entry only works if I am very close to the vehicle even then it's intermittent. Thank you in advance.
Old May 20, 2018 | 09:44 PM
revengeable's Avatar
your problem is not likely the keyless entry controller, it is more likely your remote and its battery.
if you are using the factory style remote controllers then your keyless entry controller is in the trunk under the carpeting liner almost directly under the location of the antennae.
Old May 21, 2018 | 12:34 AM
Card820's Avatar
Default Thank you
Thank you for your reply. I have used new batteries in the remote. Could the remote itself be bad? It does work, but only if I am very close to the RAP module.
Old May 21, 2018 | 05:47 AM
it could be the remote but if it is working when close it is not the controller. you can buy an additional remote inexpensively on ebay if you need another one. your car can be programmed for 4 remotes so an additional one wont be a bad idea
maybe try this out
JoeSixPack
May 10, 2018 12:34 PM
Mrestes101
May 10, 2011 10:22 PM
alanhouse
Aug 19, 2010 11:51 AM
sid0120
Jul 30, 2008 09:15 AM
cjacks9
Feb 26, 2008 04:32 PM
