2000 ford explorer rough idle
Old Apr 16, 2023 | 09:05 PM
Wyoboy7220's Avatar
Default 2000 ford explorer rough idle
I'M NEW HERE BUT MY WIFE'S EXPLORER IS A 2000 5.0 V8. IT HAD A MISS FIRE ON CYLINDER 7 SO I DID A TUNE UP AND REPLACED THE FUEL INJECTOR, WIRES, COIL PACKS AND PLUGS. FIXED THAT THEN GOT A P0171 AND P0174 LATER ON. I REPLACED VACUUM LINES, PCV VALVE AND EVEN DECIDED TO REPLACE THE ENTIRE EGR SYSTEM. STILL THE SAME CODE. REPLACED MAD AIR FLOW AND IAC, STILL THE SAME. BOUGHT A FUEL PRESSURE GUAGE AND SMOKE MACHINE, 60PSI AT IDLE AND NO LEAKS WITH SMOKE MACHINE. EVEN BOUGHT A DIAGNOSTIC SCAN TOOL AND AFTER SOME OF THE REPLACEMENTS THE FUEL TRIMS LOOKING GOOD NOW. BUT STILL LACK OF POWER AND VERY ROUGH IDLE IN AND OUT OF GEAR? HELP NEEDED! P.S. ALSO REPLACED TIMING SET MONTHS BEFORE THAT AND RAN GOOD TILL NOW. Any help is appreciated
Did the test for vacuum leak and short term ft did not drop hardly at all, stayed around 1-3%
Old Apr 17, 2023 | 01:06 AM
raski's Avatar
WHAT ARE YOUR FUEL TRIMS?
MAYBE THE ATTACHED TSB WILL HELP WITH YOUR DIAGNOSING. Good luck.
iuecbrad
Jul 7, 2012 09:34 AM
labc26
Jul 24, 2011 10:14 PM
trini8414
Apr 22, 2009 08:21 AM
rgdplg
Apr 21, 2009 11:56 AM
wheelerlt
Nov 15, 2005 09:40 PM
