2008 Ford Escape electrical problems
Old Feb 4, 2020 | 04:22 AM
Nelsonator7's Avatar
Default 2008 Ford Escape electrical problems
Good morning All: I have a 2008 Ford Escape with no radio, horn, or cruise control. I changed the radio and horn fuses with no luck. Any ideas what to do next? I’m at a loss. Beautiful well kept car, just wish everything would work. Thanks in advance.
Jeff
Old Feb 4, 2020 | 10:57 AM
Welcome to the site Jeff..
Checking the fuses,, was it visual inspection or did you check them for power with a test lamp etc?
Could be a problem within the SJB, but see if you can verify the fuses are actually hot. Some will be “hot at all times”, others “hot in run/start“, so you can just check them collectively with it idling to verify power distribution is there..
Old Feb 4, 2020 | 02:34 PM
Default Fuses
I just picked up a fuse kit today with a tester. I will let you the outcome. Thanks for the reply
Old Feb 4, 2020 | 02:36 PM
Default Fuses
I just picked up a fuse kit with a tester. I will let you know my outcome. Thanks for the reply. Oh, and I picked up a new horn just in case. Thanks again
Old Feb 4, 2020 | 03:11 PM
If you need some test points to prove out ‘issues’ let me know...
Old Feb 4, 2020 | 05:15 PM
Default Tested
I tested all fuses and replaced anyway. It looks like this car was hit by water leak. When I pulled out old fuses, They had rust on them. Would contact cleaner help. I would hate to replace SJB. Ugh. Cruise control does work, but no lights on dash. Horn and radio still doesn’t work. Could I use a round wire brush to clean contacts in SJB and contact cleaner? Maybe it will resolve the issues. Thanks for the help.
Buddy Miller
Jul 10, 2019 06:53 PM
jrs81740
Sep 16, 2017 08:48 AM
Bob Berumen
May 22, 2010 12:13 PM
sito
Nov 30, 2008 04:40 PM
armydoc
Feb 4, 2008 09:42 AM
