Crankshaft sensor
Old Jun 16, 2018 | 08:09 AM
Paco's Avatar
Default Crankshaft sensor
2000 E150 4.2 can anyone please tell me where the location of my crankshaft sensor is
Old Nov 9, 2023 | 12:31 PM
ez911's Avatar
Default I have the same request.
Where is the crankshaft position sensor on a 99 e150 4.2 v6. I can't find any information anywhere. Thanks.
Old Nov 9, 2023 | 05:11 PM
Mr. ez,,
If you are planning on replacing the CKP ,crank sensor, you might want to obtain some estimates before tackling the job..
It involves removing the crank pulley, possibly the A/C compressor and serp belt.
If there is no belt routing diagram, draw your own picture before removing.
The sensor usually is mounted on the timing chain cover just above the crank pulley next to the timing pointer..
Not a cake job. While in there once the belt tensioner is relaxed you might want to check the pulley bearings on the tensioner and replace that and the belt if worn.
Nothing like doing the job over again because we took a short cut..
Paco
Jun 16, 2018 01:43 PM
krein
Jun 27, 2009 02:59 PM
88must
Jan 3, 2008 09:07 AM
cral
Nov 19, 2007 12:38 PM
rickbraley
Oct 5, 2006 03:12 PM
