Focus door issues
Old Sep 26, 2017 | 12:49 PM
skiwings's Avatar
Default Focus door issues
Looking for help as to why water is pooling on the rear pasenger door when it rains or i was the car.
Dealer was no help, drain holes are clear & the door seals are intact, and no water is entering the car
Any suggestions?
Cant wait for winter in Michigan for the door to freeze.
Old Sep 26, 2017 | 02:42 PM
Unless someone has seen this same problem before and has the answer this is what I would do.
Remove that door interior panel covering.
With the door closed and window closed , have someone spray the door and glass area with a hose and watch for the water entry point. Usually works every time and now you or whoever is doing the repair can decide what steps may be required to correct the problem. Takes a little determination but gets to the bottom of the problem and if necessary drains can be made to allow the water to drain.
Old Sep 26, 2017 | 02:55 PM
skiwings's Avatar
thank you Hanky, appreciate it !
lossTig
May 29, 2015 02:06 PM
Bobby Braswell
Oct 29, 2013 10:20 AM
deadendstreet
Oct 28, 2013 12:38 PM
jemmybear01
Nov 3, 2011 04:52 PM
ntgardiner
Nov 27, 2006 05:02 PM
