Need help with missing at low rpm.
Old Sep 19, 2012 | 10:36 PM
J. Phillip's Avatar
Default Need help with missing at low rpm.
I have a 2002 E150 with 4.2l V6. The problem is an apparent miss that shows up usually in overdrive while trying to maintain speed on a hill or gently accelerate from around 50 mph. If I turn off overdrive in these conditions the miss does not usually appear. I have changed plugs, air filter and oil and run some injector cleaner through with little improvement. The problem seems worse when the fuel gets below 1/3 tank. Any ideas or suggestions out there?
Old Sep 20, 2012 | 03:51 AM
You might consider changing the fuel filter too.
If you still have the problem you might consider checking the fuel pump pressure and current draw under load. Most folks don't have the equipment to do all the testing we suggest and you might have to either rent it or have it done by a reputable shop.
A side note, some Ford engines don't like spark plugs that aren't Motorcraft brand. It's weird , I know , but it's true.
Old Sep 21, 2012 | 11:29 AM
J. Phillip's Avatar
Default Thanks hanky
Thanks, I will change the fuel filter when we scratch up enough money to get one and look into your other suggestions. I appreciate your time and expertise.
Phill
surferjoegomango57
Dec 11, 2013 02:32 PM
drybasement
Nov 14, 2011 07:52 PM
gvdv
Aug 28, 2010 10:39 AM
rickylg78
Nov 12, 2009 08:07 AM
motorsports12
Jul 4, 2008 11:58 AM
