no blower motor
Old Jul 30, 2011 | 03:20 PM
Warhawk68's Avatar
Default no blower motor
I have a 2004 explorer and the blower does not work. All fuses seem to be ok. Took the blower out and it works fine. Any suggestions.
thanks
Old Jul 31, 2011 | 09:22 AM
Start checking from the blower relay in the fuse panel. Either the relay is questionable or there is an open from the relay to the resistor / blower motor.
Old Aug 1, 2011 | 03:26 PM
Warhawk68's Avatar
Thank you. The relay seems to be ok as I switched it with another relay that is the same and I get the same results. I ordered a blower control switch and a blower resister. Will try that tomorrow. if that does not work the only thing I can figure is power to or from the relay. Would that be a correct assumption?
Old Aug 9, 2011 | 08:53 AM
Usually when the resistor goes south , you will lose certain speeds, but not all. I don't believe the problem is the resistor. Check the wiring under the relay. If you have a test lite or voltmeter check to see if you are getting any power to the resistor when you turn the switch on any speed but hi. Hi is direct from the switch to the blower motor.
Did you check the fuses under the hood also?
Don't overlook the heater/ A/C function switch. It provides the ground for the blower motor relay.
Old Aug 11, 2011 | 02:41 PM
Warhawk68's Avatar
I found the problem to be the heater control switch. Thanks for the advice
apollo
Sep 13, 2009 10:52 PM
SFPD770
Oct 24, 2006 06:28 PM
David Mason
May 27, 2006 08:20 PM
daleh1
Mar 6, 2006 08:46 AM
Deam
Aug 1, 2004 06:20 PM
