Tranny Problems with 2000 Ranger XLT
Old Sep 3, 2006 | 06:42 PM
vtdubconnector's Avatar
Default Tranny Problems with 2000 Ranger XLT
Hello Folks. Bought a 5 SPD 6 CYL '00 Ranger XLT with unseen tranny damage. I had trans Clutch and Rear End replaced within a thousand miles of driving. Suddenly the trans quit after moving about 500 lbs of small rocks. After replacing trans, clutch and rear end the truck did OK to even great as far as running. Recently I started having problems shifting into gears. My mechanic that I've had for 10-plus years replaced the Clutch Master Cylinder. When it came to bleeding the cylinder it was a difficult and did not seem to reach the proper pressure. After about 30 minutes of pumping and bleeding we thought we had enough pressure to operate, but within a two mile drive I went back with the same problem... Can't shift into gears. My question is this... Is the process of bleeding the cylinder a secret, or is there a reliable method to do so?or could the clutch plate or shifter be the problem because my old cylinder worked better than the new replacement, or last could the new cylinder be defective?? Did not ever see any leakage through-out this problem. Please send any and all possibilities you may know no matter how small or seemingly not important. I would like to maintain my faith in the Ford name. Thanx VTW.
Old Sep 3, 2006 | 07:06 PM
94 4x4 ranger's Avatar
Default RE: Tranny Problems with 2000 Ranger XLT
I have had a few of these it is air in the system. It is a real pain to get out the worst.Keep bleeding the system.Also tap the master and watch for air bubbles.
YNCM
Jul 29, 2013 09:58 AM
billchubbuck
Feb 17, 2009 12:19 PM
FordMomma2000
Nov 1, 2007 06:00 PM
Knox5616
Sep 17, 2006 08:53 PM
justclickn4
Jun 20, 2005 07:39 PM
