Vacuum leak?
Old Jan 11, 2012 | 02:00 PM
HamDawg06's Avatar
Default Vacuum leak?
I have a 2004 F-150 Supercrew V8. When I took it to Advance Auto the code my truck threw was Bank 1 Bank 2 running lean. Evidently it is better for my truck to run richer than leaner. The tech. there also said I may need to use a smoke machine to see if I have a vacuum leak somewhere or it also may be an electrical problem?
I had to replace my air flow sensor on my cold air intake 3 weeks ago and sure enough that was the problem at the time. Now this new code is reading that I am running lean.
Any suggestions? Will this do any longer term or significant damage if I don't take it to Ford to get it looked at anytime soon?
Any info will be of great help.
Thanks,
Chris
Old Jan 11, 2012 | 09:32 PM
greasemark's Avatar
It can be a problem if the fuel mixture is that upset that it either detonates or pre-ignites. Either happening for a length of time is not good for the long term durability of the engine. The most deadly are misfires; they KILL catalysts really quickly. Usually, they can give you a specific code (like a P0171) or something more.
If you can provide that , then we can give you a few more things to look for.
HamDawg06
Jan 11, 2012 01:43 PM
CrownVic2007
Sep 8, 2011 12:02 AM
Don954
Feb 7, 2011 01:12 AM
rj ford fan
Dec 13, 2010 06:30 PM
mikeyp
Jan 27, 2007 09:12 PM
