News, Updates and Announcements Stop in here to get the latest on FF happenings! Tips and tricks for site use can also be found here, just take a look.
2007 F150 XLT misfire
Old Feb 9, 2023 | 03:55 PM
MichaelHurt1253's Avatar
Default 2007 F150 XLT misfire
I Have a 5.4l that has been misfiring on cylinder 5 but now the OBD is saying it’s swapped to cylinder 2, I have no idea what would cause it to swap banks completely as I just had the spark plugs done
Old Feb 9, 2023 | 05:16 PM
aquanaut20's Avatar
Take it back to the people that changed the plugs..
Old Apr 18, 2023 | 09:24 PM
Jeebas11's Avatar
Default Swapped coil packs?
Learning how to change mine recently in the 5.4 when changing all the plugs you have to remove the coil packs first, and not being numbered, my guess is that cylinder 5's pack was the issue, and now it's migrated to #2 upon reinstall. You could switch just the packs one more time and see if the code migrates again to be positive, or put a new one on 2 and return if not.
P.s. I am by no means qualified, just what I see. Godspeed 🙂
Old Apr 22, 2023 | 04:31 AM
raski's Avatar
Your theory is a good possibilty.
Old Apr 22, 2023 | 07:00 AM
Considering #2 is the second cyl on the right bank and #5 is the second cyl on the left bank, if the wires are long enough a mix up could have taken place.
Believe the alternator is in the way to do that , but anything is possible.
Old Apr 22, 2023 | 11:34 AM
raski's Avatar
That's the best solution. Why give the shop an excuse to deny any mistakes which could have been done by them.
pujols
May 14, 2022 11:20 AM
Karl graves
Apr 12, 2022 08:45 AM
Barry65
8
May 29, 2021 10:29 AM
inditen
Oct 13, 2007 10:02 AM
digirolad
Mar 1, 2006 01:11 PM
