Engine idenity
Old Jun 30, 2021 | 12:43 AM
AuHunter78's Avatar
Default Engine idenity
My truck: 1965 ford f100. Recently purchased from private seller. Was told it has 302. Unable to verify. Unable to find cast mark. Read online to count valve cover bolts as a 302 has 6. My covers only have 5 bolts. What's going on? Was i mislead by seller about engine?
Old Jul 10, 2021 | 09:13 PM
Sanddoc's Avatar
FE engine
Old Jul 11, 2021 | 01:05 AM
AuHunter78's Avatar
Default More Engine Info
Originally Posted by Sanddoc
FE engine
I finally found the Cast Mark and tried to decode it, but am lost!
CODE:
D20E 6015 AB
So, my question is, is it a 302?
Thank you
Old Jul 11, 2021 | 08:02 AM
Sanddoc's Avatar
I said the engine is a FE 331 (352) 390 427 428 etc:
the 302 is a Windsor block 260 289 302 351...
they are not interchangeable... the FE has a Round bell housing... with a C4, C6 automatic or a manual transmission. 3 or 4 speed
So you have a Big Block Ford
Is it a 4bbl or 2bbl?
BTW very hard to tell which CI you have, Ford did not stamp them in fact most of the FE blocks have a 352 stamping
Now that tag is unknown to me.
first it's a industrial engine tag.. the F100 should have a 17 digit number.
Industrial engines I think are for the heavy duty truck line which started around 1958.. and I have no knowledge regarding them
when you buy a used car or truck with an FE block, you can not tell from looking at the block which CID you have.
not with standing someone boring and stroking their engine.
https://www.foleyengines.com/tech-ti...al-model-year/
thats the best I can do for you, Took me 20 min on the net to find this...
Best
Old Jul 11, 2021 | 09:40 AM
AuHunter78's Avatar
Best
Thank you for the info. The carb is a 4 Barrel. The trans is a c6, auto.
marshmellow83
Feb 18, 2021 10:47 PM
Gregski
May 14, 2010 11:08 AM
fordimca
Oct 13, 2008 10:58 AM
bigbadwolf
Jul 31, 2008 10:42 AM
tom991
Jun 19, 2007 10:44 AM
