This kit was purchased but never used. All parts are in original packaging, never opened. Took pictures of items in packaging as well as posted stock pics from the product's website. This is for a stock 6.4 Ford. I live in Los Angeles, so if you're in the area we can do local pick up or drop off. I can also ship this since everything is in its original packaging. I'm also selling this on ebay, just paste "BulletProof Oil Cooler System, Relocation Kit, 2008-2010 F-Series 6.4L Diesel" into the ebay search bar and it should pop up.
Product description from the manufacturer's website:
BULLET PROOF DIESEL 6.4L OEM OIL COOLER RELOCATION KIT
Relocate OEM Coolant-To-Oil Cooler In Easy-To-Access Underhood Location
Easy To Service Spin-On Oil Filter
Makes Oil Cooler Maintenance And Servicing Super Easy
Real World Tested and Patented Product
Description
This package is designed to remove the factory engine oil cooler from the location under the intake manifold and turbochargers and relocates it to the drivers side of the truck, under the brake booster. This package includes all of the hardware, hoses and seals for the installation. This package also includes a brand new Ford engine oil cooler.
This oil cooler kit also replaces the stock oil filter with a remote-mounted spin-on oil filter. The spin-on oil filter is simple: what you see is what you get. This means no more broken oil-filter-to-crankcase drain valves or engine oil bypass valves to worry about.
Before You Purchase: This product is designed to work with a STOCK 6.4 Ford .
