E250, MPI 5.8l C6
Old Apr 29, 2015 | 07:21 PM
BilldarrAZ's Avatar
Thumbs down E250, MPI 5.8l C6
Hello again. I get that 2,000RPM fast idle while driving. If kill the engine and restart, idle normal returns. I don't believe it's the throttle cable. Is it passable the "Kick down" might be sticking? This happen after warm / normal temp. I have a throttle cable but haven't replaced it. I did a TPS resistance and check good. Should I replace the TPS anyway? I'm frustrated.
Thanks for feedback on this issue.
BilldarrAZ
Old Apr 30, 2015 | 05:58 AM
Something is causing the computer to increase fuel to the engine and if there is no check engine light you might try to have the computer checked for any pending codes that might provide some direction. A good part of the time extra air is getting into the engine and sensors can cause the computer to increase fuel to correct a lean condition. Suggest you look for a cracked or leaking vacuum hose or PCV system hose/rubber connection that may have a crack or hole in it.
Old Jun 3, 2015 | 04:53 PM
BilldarrAZ's Avatar
Default the story continues...
I accidentally found what I think is a temperature sensor on a intake runner , driver's side between cylinder 5-6, could this be A/F temperature? My vacuum linare all okay. I checked everything; a interesting project.
Thanks for your help!
BilldarrAZ
May 6, 2015 03:53 AM
borg2offive
Dec 16, 2008 09:47 PM
mhs53
Sep 27, 2006 10:16 AM
livephc
Jun 28, 2006 10:34 PM
rebbs
Oct 16, 2005 08:37 AM
