Heater Core
Old Jun 26, 2019 | 05:54 PM
Ar1zona's Avatar
Default Heater Core
I'm in need of a new heater core, I'm rebuilding a 352 on my 1964 Ford f100 and will be putting in a new water pump as well as new radiator. I would like to replace the heater core as well, does anybody know where I can get a new one?
Old Jun 27, 2019 | 07:08 AM
Use Common Sense's Avatar
Old Jun 27, 2019 | 08:44 AM
Ar1zona's Avatar
I did look there most of their heater cores start at 1965 and on but not 1964!
Old Jun 28, 2019 | 08:11 AM
OK...Do you know what the dimensions are and the Inlet/Outlet size and set up is?
Old Jul 3, 2019 | 04:04 PM
Ar1zona's Avatar
Default Heater Core
It is still in the truck, I looked at Macs and other catalogs and some of them only go back as far as 65. Could I use a 65 if the dimensions are the same? I plan on having the engine rebuilt and a new radiator. I don't want to mix new parts with old. Also with a new water pump it might make the old heater core leak!
Old Jul 4, 2019 | 10:01 PM
If the 65 is the same dimensions as yours, I don;t see why it wouldn't work. You could always see if you have a radiator shop around that could re-core yours.
Old Jul 9, 2019 | 11:00 AM
Ar1zona's Avatar
Default Heater Core
OK...Thanks!!!
Hunter Johnson
Mar 1, 2019 12:06 PM
ridgedalefarm
Oct 2, 2017 09:58 AM
Casey
Jan 15, 2009 06:35 PM
BlueOvalFitter
Jul 5, 2008 11:38 AM
adam
Apr 1, 2007 09:39 PM
