Trouble with 78 400
Old Jan 24, 2019 | 04:56 PM
Mightyox's Avatar
Default Trouble with 78 400
It's a LTD with new distributor, plugs, wires, carb, ICM, fuel pump and gas tank. It runs until it gets hot then it sputters and stalls. Any help would be great. The smog pump is bypassed.
Old Jan 24, 2019 | 07:27 PM
Pick up coil was a possibility along with ICM
Old Jan 24, 2019 | 07:32 PM
Mightyox's Avatar
Pick up in the distributor? New coil.
Old Jan 24, 2019 | 07:38 PM
Generally,, during heating or extended driving the ICM would fail, causing a no start/stall condition. After some cooling, a restart would be possible and likely.
Although more rare or less cause, a pick up coil could would drop out, or loose signal with similar affects..
Old Jan 24, 2019 | 07:47 PM
Mightyox's Avatar
I believe that came new with the distributor unless we are talking about something different.
Old Jan 24, 2019 | 07:51 PM
Mightyox's Avatar
Could it be the EGR?
Old Jan 24, 2019 | 08:35 PM
Distributor wasn’t mentioned prior,, EGR application shouldn’t be at idle, although easy enough to prove out..
Old Jan 24, 2019 | 08:39 PM
Mightyox's Avatar
How can I test the EGR?
Old Jan 24, 2019 | 09:18 PM
Unless the EGR is open/bleeding removing the vacuum hose will eliminate EGR application.. The temp doesn’t seem to follow EGR,, So,, hot meaning what?
Old Jan 25, 2019 | 05:28 AM
Mightyox's Avatar
Hot meaning running temp. Could it be the carb is to rich when it gets warm and is flooding it out.
