Sights 'N Sounds Post Video and Sound clips here. This forum is for video's pertaining to Ford's, Racing (Street/Strip), Interviews, and Off Topic.
Knocking sound after head gasket replacement
Old 06-26-2017, 03:44 PM
hoschi1974's Avatar
Default Knocking sound after head gasket replacement
Hello,
as described in topic, there is a kind of unregular knocking sound.
When starting the engine it runs nice and smooth, and no strange sound at all.
But when itīs getting warmer this knocking sound suddenly appears, sounds a bit like beating metal, but it is not regular at all. The warmer the engine becomes the louder the sound is. When accelerating, the sound disappears.
When shift into D or R the sound changes, but itīs louder. Have a look at my video, there you can hear:
Thank you all!
Old 06-26-2017, 05:07 PM
How are the torque converter to flex plate bolts and the flex plate itself?
Old 06-27-2017, 01:25 AM
hoschi1974's Avatar
I didn't take this apart, there is no need to. I didn't touch that.
Old 07-01-2017, 10:02 AM
hoschi1974's Avatar
Could it be the crankshaft? Respectively the bearings?
Old 07-01-2017, 01:09 PM
Sometimes things happen even if you never worked there. It's easy enough to remove the inspection cover at the lower end of the engine . Just as you feel you didn't work on the main brgs , it could be involved.There are a few things you might check , crankshaft end ply, torque converter flex plate, crankshaft pulley which sometimes will separate from the bolted section. Whether you worked there or not , the idea is to determine the source of the heavy rumble. I have heard noises like this when spark plug wires were not in the right firing order.
Did you compare the replacement gasket(s) to the ones you removed?
Rod brgs don't produce that heavy rumble , but mains can.
Old 07-05-2017, 04:04 PM
hoschi1974's Avatar
Thanks hanky!!
2 spark plugs were in the wrong firing order, cylinder 1 + 3 were wrong.
Connected them in the right way, now engine runs like a charm... incredible :-)
So easy.... Took me 2 weeks though.
Old 07-05-2017, 07:27 PM
Thanks for the update..
Old 09-14-2017, 01:56 AM
jamesmsmall's Avatar
you can check also here: https://www.bigboyscartoys.com/
chillywilly454@aol.com
09-19-2010 11:59 AM
flaco954
08-09-2009 05:44 PM
bill9iron
05-06-2009 06:22 PM
mrmike
07-14-2007 01:43 PM
mike0179
04-25-2007 06:25 AM
Quick Reply: Knocking sound after head gasket replacement
