South West AZ, TX, NM, OK
1954 Ford Skyliner - door won't open?
Old Mar 12, 2019 | 10:24 AM
WinPearl's Avatar
Question 1954 Ford Skyliner - door won't open?
I need to help to get my driver's side door to open. The door will not open from outside or inside the car. Help! What do I do?
Old Mar 12, 2019 | 01:55 PM
;Worth a shot.
Roll the driver's side window all the way down. Now you can see the door latch mechanism with a flashlight. You may be able to see what moves or is supposed to move when you attempt to release the latch. If they used a button that you pushed down so the door canniot be opened from the outside just lift the linkage that the button releases when you pull it up. Don't remember what system they had then . Let us know if this helped you or not.
jackiel
Sep 18, 2014 06:11 PM
MrsRiot
Jan 23, 2012 12:37 AM
billtn
May 24, 2011 08:18 PM
luker
Apr 26, 2009 08:34 PM
Brooklyn67
Sep 8, 2007 12:46 PM
