Ford Contour While only built on a short time span, the Contour was very popular with people of all driving styles, from the base model making for a great family car, to the SVT making a great track toy.
Driver door stuck closed
Old Jan 22, 2012 | 05:19 PM
MrsRiot's Avatar
Default Driver door stuck closed
So I need help bad! The other day my driver door started not closing so my mechanic looked at it and said it was the latch assembly. So I ordered a new one and attempted to install it. I got it installed and when I shut the door to try
It, it got stuck. Now the door won't open at all from the inside or out. When I press the unlock button I hear nothing but when I press the lock button i can hear it as if it's trying to lock. The door panel is off of the door but I can't for the life of me figure out how to get the latch to unlatch so that I can open my door. It's a 2000 contour btw.
Any help is greatly appreciated!!
Old Jan 22, 2012 | 06:29 PM
I would suggest that you look as closely as you can for the connection where the door locking motor operated a rod or link. The locking section sounds like it is stuck in the partially locked position. Be careful not to bend anything . Once you can get it to the fully unlocked position , it may allow you to release the latch assy ,or at least release it from the inside with the door latch release handle.
Old Jan 23, 2012 | 12:37 AM
MrsRiot's Avatar
Will give it a try tomorrow when there's plenty of light. Thanks for the suggestion!
phisherman
Apr 11, 2016 12:11 PM
j41
Sep 2, 2015 12:30 PM
alkrema
Jun 24, 2015 04:28 AM
spatterfree
May 3, 2014 09:34 PM
BluProbeGT
May 31, 2007 03:37 PM
