Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
6' lift
Old Sep 14, 2005 | 01:32 AM
big_yellow's Avatar
Default 6' lift
I have a 1979 f150 i never done any suspension work so please help me out here.....
What is all needed for 6' lift all i need to know is what parts i need
Thanks
Old Sep 14, 2005 | 01:15 PM
Mobile AV's Avatar
Default RE: 6' lift
You have some work ahead of you.
We carry suspension systems for Fords (nothing in your era though). Here is a parts list for what you would have to upgrade for a F-150 6" suspension system.
* Torsion bar / cross-member and front differential drop brackets
* tubular subframe braces
* Rear riser blocks & u-bolts
* Longer coil springs / shocks
* caster brackets
* steering stabilizer
* track bar
* and more
With all that being listed, you still will have to figure out what will happen to your drive shaft. Will it be long enough? What kind of u-joints will be needed as your drive shaft will be at an angle rather than parallel to the ground..etc.
Huk
Mar 7, 2012 12:03 PM
604x4
Mar 2, 2012 10:27 AM
Huk
Mar 1, 2012 07:55 AM
hepcatws6
Aug 13, 2004 01:31 PM
hepcatws6
Aug 13, 2004 01:30 PM
