1998 F150 5.4 won't shift from 2nd to 3rd
Old Apr 3, 2007 | 06:31 PM
roy6578's Avatar
Default 1998 F150 5.4 won't shift from 2nd to 3rd
I have a 1998 F150 that I just purchased and I am having Transmission problems! I don't know if the whole transmission needs to be replaced or if it is a shifting sensor or if this is a minor problem that can be fixed without replacing the whole thing? It will go into 1st and 2nd gearbut won't 3rd. When you run diagnostics onit the EGR code comes up!ANY SUGGESTIONS? HELP!
Old Apr 4, 2007 | 03:40 AM
goinstrong's Avatar
Default RE: 1998 F150 5.4 won't shift from 2nd to 3rd
EGR and intake manifold vacuum problem could be messing up the transmission vacuum. Bad converters can cause block pressures and ruin intake vacuum.
Old Apr 4, 2007 | 03:41 AM
goinstrong's Avatar
(Catalytic converter(s)).
lt e5
Sep 10, 2014 08:49 AM
go300mph
Dec 31, 2010 10:08 PM
kc2121
May 5, 2010 02:24 PM
96FordProbeSE
Oct 27, 2007 09:44 AM
dilligaf58
Sep 12, 2006 06:55 PM
