1st & 2nd shift problems
Old Jul 24, 2014 | 03:38 PM
gwswatcha's Avatar
Default 1st & 2nd shift problems
I have a 5r55e from a 2000 explorer that I rebuilt and installed in a 1997 ranger when transmission is cold it shifts great but as soon as it reaches normal operating temperature it shifts hard from 1st & 2nd and downshifts hard from 2nd to 1st.Took yellow spring out of intermediate servo and upshift got better but downshifts stayed the same.I have checked codes and corrected those issues with no results anybody have any suggestions.
Old Jul 24, 2014 | 07:27 PM
If you haven't tried this yet , give it a try.
Disconnect the coolant temp sensor and you will get a c/e lite, but what we are trying is to prevent it from going into closed loop where the PCM controls some outputs. If it stays working ok then I would suspect there is some conflict between the 2000 PCM and the 1997 PCM.
drhoads
May 11, 2013 03:34 PM
JCC
May 10, 2013 11:03 AM
Fordtough95
Apr 26, 2012 03:32 AM
dilligaf58
Sep 12, 2006 07:57 PM
dilligaf58
Sep 12, 2006 06:55 PM
