Doing tranny swap can I?
Old Mar 20, 2019 | 09:25 PM
Troy Patterson's Avatar
Default Doing tranny swap can I?
Swapping out the transmission in my 93 Ford crown Vic. I believe it's a AOD and I'm putting in a 4R70W. Do I need to get a new flexplate or can I use the old one even though it was for a AOD transmission? Or could I just use my AOD TC in the 4R70W to the old flexplate?
Old Apr 7, 2019 | 10:39 PM
imp's Avatar
imp
The AOD uses a special torque converter which has two output shafts, one being the usual shaft turned by the oil-driven member, the turbine, the other driven by the "pump" which is connected directly to the engine. So, AOD was "no torque converter" in action in 3rd. and 4th. gear. So, no, It's not usable with a 4R70W.
AOD was a NON-Electronic transmission, strictly mechanical. It was upgraded to electronic as the AODE, which was further upgraded to the 4R70W. The 4R70W would require use of all the sensors needed by it, as well as a computer capable of running it. I believe a "stand-alone" controller may be available for it.
I worked with a guy named Troy Patterson in Phoenix. You couldn't be him could you? My name is Steve.
VicOwner2018
Sep 29, 2018 01:56 PM
tomsteve
Nov 14, 2012 04:39 PM
torino_john
Jun 19, 2009 01:31 PM
Badd_Company
Feb 26, 2005 12:44 PM
semperfi48103
Aug 30, 2004 02:28 AM
