Help with tranny codes overdrive light blinking
Old Feb 8, 2011 | 07:06 AM
redfalcon's Avatar
Unhappy Help with tranny codes overdrive light blinking
Recently had codes read on my 1999 E-150 and found P1000,P1288,P1711,P0713.mechanic replaced internal wire harness with diode on it, this was a temp sensor. 50 miles later I had what seemed like a lock-up of some type then blinking OD light again.......I'm trying to avoid money pit.Anyone have specific knowledge as to what else up the line it could be ? Bad computer ? Blinking now comes and goes.Any suggestions would be appreciated.
Old Feb 8, 2011 | 07:39 PM
I believe the 1288 code involves the cylinder head temp sensor also ck the TPS.
The fact that it comes and goes indicates it is an intermittent problem which could be caused by a loose or poor elec connection.
P1000 indicates a drive cycle has not been completed. Was the battery disconnected shortly before the codes were read?
Anytime a trans code is coming up , I always start with checking the plug and pin connections on the trans. They are noted for corroding inside and this can usually be spotted by the green corrosion on the pins. A good cleaning with a good penetrating oil usually cleans them off enough to eliminate the connection problem.
The other two codes involve the trans. Anytime we get a load of trans codes it usually indicated a ground connection is the culprit.
Old Feb 9, 2011 | 07:07 PM
redfalcon's Avatar
Smile
thanks hanky , I'm on the job ,seems I have a coolant leak ,this may not be helping the situation.I will getting a much closer look this comng weekend,weather permitting All info is valuable.Thanks again. redfalcon
mcco
Dec 9, 2015 04:06 PM
doug2118
Sep 18, 2012 05:24 PM
Bob Lobblaw
Apr 9, 2009 09:00 AM
jersitron
Mar 19, 2008 05:38 PM
kyford
Feb 4, 2007 04:10 PM
